Upgrading Throttle body on e30 325i
JagsK1981
Post Fri Feb 17, 2017 10:26 am
Hi
I was told to upgrade my throttle body on my sport. Any recommendations on doing this?
Post Fri Feb 17, 2017 2:08 pm
What makes you think that the one BMW fitted is deficient in any way?
JagsK1981
Post Fri Feb 17, 2017 5:11 pm
Was told to do that to get better performance, is that right?
Post Fri Feb 17, 2017 6:25 pm
Slightly better throttle response.
On its own it will barley give any extra power.
Post Fri Feb 17, 2017 8:09 pm
It will only do anything noticeable if the engine is modified in other ways to increase the required airflow through it, such as a capacity increase or a longer duration/higher lift cam, etc.
Post Fri Feb 17, 2017 8:13 pm
I have a 325i with a btb six branch exhaust manifold and a BBR star chip.
I fitted a bigger bore throttle body and there was a noticeable change in throttle response.
The most comparable thing to it is when you press the 'sport' button in a later BMW M car with a fly by wire throttle such as an E46 M3 or E39 M5 and you notice the change in throttle.
jimbom30cab
Tech 1 freak
Post Fri Feb 17, 2017 9:57 pm
I agree with Barry, the throttle response is quite noticeable. Bizarrely I also got a couple of MPG extra from doing this. The engine also has a slightly more raspier note to it.
reggid
Post Sun Feb 19, 2017 2:39 am
its way down the list of things the m20 needs to make power.
E30 325is with M20B31
