Hi
I was told to upgrade my throttle body on my sport. Any recommendations on doing this?
Upgrading Throttle body on e30 325i
- Brianmoooore
What makes you think that the one BMW fitted is deficient in any way?
Slightly better throttle response.
On its own it will barley give any extra power.
- Brianmoooore
It will only do anything noticeable if the engine is modified in other ways to increase the required airflow through it, such as a capacity increase or a longer duration/higher lift cam, etc.
I have a 325i with a btb six branch exhaust manifold and a BBR star chip.
I fitted a bigger bore throttle body and there was a noticeable change in throttle response.
The most comparable thing to it is when you press the 'sport' button in a later BMW M car with a fly by wire throttle such as an E46 M3 or E39 M5 and you notice the change in throttle.
jimbom30cab
- Tech 1 freak
I agree with Barry, the throttle response is quite noticeable. Bizarrely I also got a couple of MPG extra from doing this. The engine also has a slightly more raspier note to it.
