After reading many and I mean many threads on the world wide web I'm no wiser that before , is the ECU also known as a DME ?
ECU or DME I'm confused
Yes.
ECU = Engine Control Unit
DME = Digital Motor Electronics (e.g., Bosch Motronic).
Bonymaenjack
So just to be clear the ECU /DME is the same unit located on the drivers side below the dash and the ECU/DME has a relay which is located in the nearside engine bay .Speedtouch wrote:Yes.
DME = Digital Management Electronics (e.g., Bosch Motronic).
Cheers Keith
Indeed. However, DME can mean anything related to the engine management system, which includes sensors such as the CPS, TPS, wiring loom, relays, etc.
http://www.e30zone.net/e30zonewiki/index.php/DME
Bonymaenjack
Thanks for the explanation
