m42 engine arms
mark_i
Fri Jun 03, 2016 11:11 pm
about to drop in a M42 from a e36 into an e30.
can we use the existing e36 engine mount arms?
TIA
mark_i
Sat Jun 04, 2016 10:58 pm
also...
we will be using the e36 direct drive Getrag manual gearbox that has a wider distance between the rear mounts.
can the e36 gearbox crossmember bolt onto the e30 chassis?
AdamGardner
Sat Jun 04, 2016 11:39 pm
Not sure about the engine mounts, i use an e30 gearbox mount with an e36 box on the back of an m42!
jmc330i
Sun Jun 05, 2016 8:53 am
You need E30 engine mounts
James
'91 325i Sport
'93 318i touring 16v
mark_i
Mon Jun 06, 2016 12:13 pm
appreciate the advice.
Still concerned how to get the e36 Getrag bolted up to the e30 tunnel
jmc330i
Mon Jun 06, 2016 2:57 pm
Every E36 box I've used in an E30 (both getrag and ZF) has used the standard E30 crossmemeber.
James
'91 325i Sport
mark_i
Wed Jun 08, 2016 9:24 pm
interesting.
the rear box mount positions are at least 2 inches wider than the mount positions on the e30 cross member.
I'll get the getrag box part number and a pic...
Wed Jun 08, 2016 10:08 pm
jmc330i wrote:Every E36 box I've used in an E30 (both getrag and ZF) has used the standard E30 crossmemeber.
Same here. Needs modifying if using an engine/box combination that puts the box at an angle, but the spacing is the same.
Shouldn't be a massive problem to fabricate from scratch - it supports very little weight in an E30, which uses the mid position engine mount holes on yhe block.
