about to drop in a M42 from a e36 into an e30.
can we use the existing e36 engine mount arms?
TIA
m42 engine arms
mark_i
also...
we will be using the e36 direct drive Getrag manual gearbox that has a wider distance between the rear mounts.
can the e36 gearbox crossmember bolt onto the e30 chassis?
AdamGardner
Not sure about the engine mounts, i use an e30 gearbox mount with an e36 box on the back of an m42!
jmc330i
You need E30 engine mounts
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
mark_i
appreciate the advice.
Still concerned how to get the e36 Getrag bolted up to the e30 tunnel
jmc330i
Every E36 box I've used in an E30 (both getrag and ZF) has used the standard E30 crossmemeber.
James
'91 325i Sport
'91 325i Sport
mark_i
interesting.
the rear box mount positions are at least 2 inches wider than the mount positions on the e30 cross member.
I'll get the getrag box part number and a pic...
Same here. Needs modifying if using an engine/box combination that puts the box at an angle, but the spacing is the same.jmc330i wrote:Every E36 box I've used in an E30 (both getrag and ZF) has used the standard E30 crossmemeber.
Shouldn't be a massive problem to fabricate from scratch - it supports very little weight in an E30, which uses the mid position engine mount holes on yhe block.
