e30 rear disc conversion (handbrake mechanism)
markus_74
Post Sat Mar 05, 2016 11:50 am
Hello,
I need some info on handbrake mechanism disc style (screw adjuster, lock, pin etc) does is it same with handbrake mechanism on drum style?
I mean if it is same I can use it for my disc conversion.
Because it the most difficult parts to find.
Thank you
Markus
Number 7,3,6,5
Post Sat Mar 05, 2016 2:05 pm
All the parts above, including the cable are unique to rear disc brakes, although they are the same, except cable, on some later BMWs.
markus_74
Post Sat Mar 05, 2016 3:19 pm
Thank you for the info, Mr.Brian. So I can use or substitute from e36 handbrake? Or e30 drumbrake?
markus_74
Post Mon Mar 07, 2016 12:54 am
Does handbrake bowden cable is same between disc and drum brake?
I compare that the long is same 1725mm but while I see the part.number is different.
Disc is34411158421 and drum 34411154681
Post Mon Mar 07, 2016 10:03 am
Different fitting on the end.
