sump guards
steve_k
Post Sun Feb 21, 2016 7:33 pm
hi folks, looking at getting myself a sump guard for the sport as in the next few months it will be pressed into daily service.
now the thing is i really dont fancy paying up to £200 for a bit o bent steel plate so i'll be making my own.
what i need are two measurements, length from the front subframe (two bolt holes behind the steering rack) to the radiator mount (the metal strip beneath it) & the width between the two bolt holes on the subframe.
i would measure it myself but i'm away from the car & i don't have my jack handy (insert your own exscuse here........)
so i was hoping some one would have the measurements to hand.
if so, thanks.
Mitchen
Post Sun Feb 21, 2016 10:51 pm
http://www.ebay.co.uk/itm/BMW-E30-SUMP- ... SwuAVWvd2o
Reckon the giro will stretch to this? :wink:
1990 320i Coupe SE
viewtopic.php?t=253048
Post Sun Feb 21, 2016 11:07 pm
Mitchen wrote:http://www.ebay.co.uk/itm/BMW-E30-SUMP- ... SwuAVWvd2o
Only problem is that's not a sump guard - this plate fits under the gearbox, is a standard fitting on E30s, and is as about as effective as a chocolate fire guard in front of an open fire as regards protecting against impact.
BMW refer to this part as an air duct.
jmc330i
Post Sun Feb 21, 2016 11:08 pm
That's not a sump guard. It protects the gearbox.
James
'91 325i Sport
'93 318i touring 16v
Mitchen
Post Sun Feb 21, 2016 11:12 pm
My bad..
1990 320i Coupe SE
Post Sun Feb 21, 2016 11:14 pm
Mitchen wrote:My bad..
Yours, and the chancer trying to sell it on ebay!
Post Sun Feb 21, 2016 11:51 pm
Never mind them, imagine how the fool that buys it will feel :)
ajay
Post Mon Feb 22, 2016 6:50 am
This is an original E30 sump guard.
[URL=http://s1050.photobucket.com/user/ajspa ... 0.jpg.html]Image[/URL
Pm, if you want it for £100 collected!
steve_k
Post Mon Feb 22, 2016 8:36 am
ajay wrote:This is an original E30 sump guard.
ajay, thanks for the offer :D
i can get some 5mm thick 316grade sheet steel cheap enough, just need the measurements winkeye
