Hi all,
I think I have a faulty ABS relay, I've been looking at where I can buy replacements from but haven't been able to find anywhere just yet.
I've had a look on google and not a great deal is coming up.
I have an F reg 325i. Can anyone advise a distributor in the uk?
Many thanks in advance
ABS RELAY ??
matt86
I think I have a second hand one of these. Where in the uk are you?Bh94 wrote:Hi all,
It remains on when the ignition is on, the light never turns offwillnz wrote:What symptoms lead you to believe your relay is faulty?
What are your faulty ABS symptoms? Is your light on permanently with ign on, or does it come on with ign on, then go off, and then come on when you start moving?
- aimlessrock
there are two different types dependent on which abs setup you have...are the relays on the pump or behind the glovebox?
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
