ABS RELAY ??
Bh94
Post Fri Jan 29, 2016 10:17 pm
Hi all,
I think I have a faulty ABS relay, I've been looking at where I can buy replacements from but haven't been able to find anywhere just yet.
I've had a look on google and not a great deal is coming up.
I have an F reg 325i. Can anyone advise a distributor in the uk?
Many thanks in advance
matt86
Post Fri Jan 29, 2016 10:30 pm
Bh94 wrote:Hi all,
I think I have a second hand one of these. Where in the uk are you?
Bh94
Post Sat Jan 30, 2016 11:12 pm
willnz wrote:What symptoms lead you to believe your relay is faulty?
What are your faulty ABS symptoms? Is your light on permanently with ign on, or does it come on with ign on, then go off, and then come on when you start moving?
It remains on when the ignition is on, the light never turns off
aimlessrock
Post Sat Jan 30, 2016 11:47 pm
there are two different types dependent on which abs setup you have...are the relays on the pump or behind the glovebox?
E30 320i Convertible (1989)
190 Mercedes (1988)
matt86
Post Sun Jan 31, 2016 12:14 am
On mine they are behind the glovebox
