hi there, first post on here I've just finished replacing my fuel tank and after putting some fuel in it there is a small leak i noticed that the filler neck hose has some slight corrosion on it and i believe that is where the leak is coming from i have called bmws and they have quoted me £245 for a whole new filler neck system does anyone know any where that does just the hose???
please help!!!!
in desperate need of a new filler neck hose
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
contact mick by PM (magpie). I'm sure he had a few for sale recently or search the parts for sale section.
Gert_8
Are you looking for the steel filler pipe or the hose that joins the pipe to the tank? Both can cause leaks. The £245 item is the steel pipe.
mikeypatrick1993
I'm after the hose, the steel pipe is in good condition its the rubber hose that I'm in desperate need of.
The hose is available from plenty of scrap cars found in the parts section
KW355
I brought a filler hose from bmw about 6 months ago. It was about £30 I think.
a rubber filler hose from BMW is not £30 ^ try double that and a bit more .... i have kept loads of these from breakers because of this reason .
Thanks Gerty
Thanks Gerty
+ a yard full of scrap turds
KW355
[quote="magpie"]a rubber filler hose from BMW is not £30 ^ try double that and a bit more .... i have kept loads of these from breakers because of this reason .
I don't know if these have gone up in price since April this year but I paid £29.12 including vat for mine from Sytners Solihull. Part number 16121180402 is common to both M3 and other e30's.
The hose for the M3 extra tank was £24.07 plus vat and the filler flap rubber boot was £18.15 plus vat.
