in desperate need of a new filler neck hose
mikeypatrick1993
Post Wed Nov 11, 2015 3:17 pm
hi there, first post on here I've just finished replacing my fuel tank and after putting some fuel in it there is a small leak i noticed that the filler neck hose has some slight corrosion on it and i believe that is where the leak is coming from i have called bmws and they have quoted me £245 for a whole new filler neck system does anyone know any where that does just the hose???
please help!!!!
Gert_8
Post Wed Nov 11, 2015 4:16 pm
contact mick by PM (magpie). I'm sure he had a few for sale recently or search the parts for sale section. :)
Gert_8
Post Wed Nov 11, 2015 4:18 pm
Post Wed Nov 11, 2015 6:25 pm
Are you looking for the steel filler pipe or the hose that joins the pipe to the tank? Both can cause leaks. The £245 item is the steel pipe.
mikeypatrick1993
Post Thu Nov 12, 2015 8:18 am
I'm after the hose, the steel pipe is in good condition its the rubber hose that I'm in desperate need of.
Post Thu Nov 12, 2015 9:00 am
The hose is available from plenty of scrap cars found in the parts section :D
KW355
Post Thu Nov 12, 2015 10:13 am
I brought a filler hose from bmw about 6 months ago. It was about £30 I think.
Post Fri Nov 13, 2015 8:31 am
a rubber filler hose from BMW is not £30 ^ try double that and a bit more .... i have kept loads of these from breakers because of this reason .
Thanks Gerty :cool:
Post Fri Nov 13, 2015 8:33 am
KW355
Post Sat Nov 14, 2015 2:08 pm
[quote="magpie"]a rubber filler hose from BMW is not £30 ^ try double that and a bit more .... i have kept loads of these from breakers because of this reason .
I don't know if these have gone up in price since April this year but I paid £29.12 including vat for mine from Sytners Solihull. Part number 16121180402 is common to both M3 and other e30's.
The hose for the M3 extra tank was £24.07 plus vat and the filler flap rubber boot was £18.15 plus vat.
