Evening all,
I'm on the lookout for a Weber 32/34 DMTL carb for my 316 M10 as the Pieburg one that's on it currently is giving me hassle - erratic idling, engine cutting out when slowing, etc. I'd thought it was an air leak but according to my mechanic unfortunately the carb is on it's way out Sad
I've found a couple online for £300+ but I was wondering if anyone here might know of anywhere I could find one cheaper?
Second hand is also an option.
M10 weber carb options
- aimlessrock
for the sort of money that you are looking at for another carb why not drop a 316i engine in?..the whole conversion is unlikely to costs more than 300 and the economy will be much better.
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
- Brianmoooore
One or other of the zone traders usually have one of these available second hand. Check that it comes with the top adaptor, to fit the OE air filter box.
scottybeemer
ive got a problem with mine,runs fine but its just a pain starting,ive got a 318i full car standing and wondering if its worth taking the injection side of it off and using it on my 316
"you aint gonna take me alive, copper"
It is not quite as straightforward as some internet experts will have you believe
You will need to swap the tank, fit a return line, fit a fuel pump and associated wiring, change the cylinder head ( carb head ports won't match up to injection manifold) and loads more.
I would keep hunting for a good Weber kit. They are out there.
