Hi guys, in need of a little help on which starter motor to use?
am building 92 non vanos m50 2.5 with 5 speed box from e36 with m52 2.8 crank and 240mm solid/lightened flywheel clutch kit, do I use m52 2.8 starter motor? Have looked/searched everywhere and can't seem to find a definite answer, any help greatly appreciated.
Which starter motor
- motormanmick
- motormanmick
Thanks guys, flywheel is designed to replace dual mass oem 240 mm m52 2.8 flywheel, kit is everything, lightened 240 mm single mass flywheel, clutch pressure plate to suit and clutch plate, so should get m52 2.8 starter motor?
- motormanmick
Thanks Dan, awesome
