Hi, I've done an M52B28 swap into my old Touring. Done all to high standard with all new gaskets, seals, water pump etc. Fitted a lightened M20 fly and re-used my M20 clutch.
Issue I'm having is vibration from engine at 2k, feels like something out of balance. I suspect the fly or clutch. Think as clutch was fine before then it should still be. Dont know if a flywheel can become unbalanced by skimming on a proper lathe?
Anyone got any ideas?
Cheers Joe
rumble at 2k
sweep
Exhaust not catching near front subframe anywhere?
Cloggy Saint
bosers
Thanks for replies, no have sorted exhaust recently as I thought bodged welding job near manifold may have been the cause. The prop is fine also,transfered from previous set up. This is is a vibration that is noticeable when revving at standstill, the whole car vibrates a bit. I was so hoping it was just the exhaust
It now feels like the fly or the clutch to me .
