I have recently purchased an e30 saloon, my initial issue was the pierburg carb on the engine that was performing poorly.
I got myself a weber 32/34 DMTL which fits my engine. I am not mechanic nor do I have experience in fitting carburettors.
I have been told these can be straight forward an I have looked in the wiki section and also researched online for anything that can help me fit mine and how goes where.
does anyone have any images or step by step guides with images on how to go about this.
please look at the images below and any direction or suggestions are appreciated.
My first issue is fitting the throttle cable to the new carb, am I just removing it from this (second picture) metal frame and if so I then need to fit it to the carb. I have an idea of this but again as I am new any advice or tips are welcomed.
Also as the old air filter bin lid style air filter box will not fit ontop of the weber, this pipe that lead from the engine to the airfilter has nowhere to go, am I removing it and what do I do here??
does anyone know what these hoses are for and where on the carb they are going? Apologies again if these questions are basic.
Also the hose on the left in this picture needs to go somewhere on the carb im presuming as it was pulled from the pierburg.
would really appreciate any feedback and advice, also if you have images for me to follow or links to any kind of step by step videos would be great.
Also I am presuming I need a new air filter for the weber, advice on what I will need would be great too!
