Hello all,
the head cracked on my m50b25
i have sourced a m52b28 however has ews so could i use the red label ecu of the m50 il be using the m50 intake
e34 525i 413 red label on m52 2.8i
Not if you want it to run right.
The M52 management is light years ahead of the old M50, fitting M50 management to an M52 is a downgrade.
Either wire up the EWS or get it deleted from the ECU
ben-yatess
Ah right ok, so where and how much to get a delete? and also is wiring the ews up difficult?
cheers
cheers
bimanut
Look closer at the post above you
jmc330i
Wiring up the EWS is not difficult, it's about 7 wires iirc and the added security is always a good thing. But if wiring and soldering isn't your thing, speak to Dan above about EWS delete.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
