e34 525i 413 red label on m52 2.8i
ben-yatess
Thu Apr 30, 2015 12:55 pm
Hello all,
the head cracked on my m50b25
i have sourced a m52b28 however has ews so could i use the red label ecu of the m50 il be using the m50 intake
Thu Apr 30, 2015 1:15 pm
Not if you want it to run right.
The M52 management is light years ahead of the old M50, fitting M50 management to an M52 is a downgrade.
Either wire up the EWS or get it deleted from the ECU
ben-yatess
Thu Apr 30, 2015 3:21 pm
Ah right ok, so where and how much to get a delete? and also is wiring the ews up difficult?
cheers
bimanut
Thu Apr 30, 2015 4:19 pm
Look closer at the post above you
jmc330i
Thu Apr 30, 2015 4:27 pm
Wiring up the EWS is not difficult, it's about 7 wires iirc and the added security is always a good thing. But if wiring and soldering isn't your thing, speak to Dan above about EWS delete.
James
'91 325i Sport
'93 318i touring 16v
