Another plea for help I'm afraid
The door switches aren't fitted/plugged in if that alters anything. All testing with the ignition on. The passenger window works fine, and I've swapped the switches over and the problem is still the same.
With the driver's window, which is stuck down in the door, when I press the switch, in either direction, the motor clicks/strains for a second or so, and then stops. The regulator makes no attempt to move. I assume it's not a wiring issue, but rather, a seized motor/gearing. Given the window is at the bottom of the door, even if I unbolt the regulator, I won't be able to remove it. Is there a way to move it up manually so I can remove it and strip the motor for repair? (I don't have the funny tool thing.) Or am I barking up the wrong tree?
Cheers,
Joe
