Hi Zoners,
Fitting original mtech 2 coupe side skirts on a convertible wouldn't look quite right would it? Wonder what the visual difference is..?
It's so difficult to find original cabby tech 2 side skirts..?
But, what makes them unsightly compared to the coupe version on a cabby?
I know this wouldn't be right... But could you modify the coupe pair to look as a good cabby pair?
Mtech 2 cabby side skirts
MPOWERCRAZY
coupe skirts will fit a convertible with slight modification, you will need to trim the lower half of skirts to sit flush with the sill, will look the same as original tech 2 convertible skirts.
Back Again From The Darkside Of Doing E36'S
Back With 2 E30 Projects
Tripper
Thanks for the reply Mpowercrazy!
Any visuals on what needs trimming?
Thanks, tripper
Thanks, tripper
Tripper
Anyone....?
E30cabalan
