Bonnet Insulation Foam
Mitchen
What's the best way to get rid of this guys?
I've removed the foam.. just left with the layer stuck to the bonnet.. Anyone got any special formulas?
Also in terms of fitting a new one, Is it best to remove the bonnet to line up the adhesive correctly. Seems tricky getting it all lined up while leaning over the engine.
jimbom30cab
- Tech 1 freak
Some say......Toyota brake cleaner is the best (god knows why)
Mitchen
An old wifes tale maybe
How do you usually get it off Jim?
jimbom30cab
- Tech 1 freak
Bit embarrassed here.... but normally the local body shop do it as part of a re-paint job
I think they use thinners but can't be sure
I did one once with a rotary very very soft wire brush on slow speed, but I wouldn't recommend it.
Mitchen
Yeah I was thinking it's going to take some sort of solvent.
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Barry is the one that recommends the Toyota brake cleaner
gooner1
- Out humping Reindeer
Yep it was me that discoverer how good Toyota brake cleaners is at removing the glue residue.
Turns it to mush that just wipes off.
I think any solvent based brake cleaner should do the job though.
Mitchen
Well i be damned.. I'll give it a crack!
What was the cutter you recommended for getting rid of that overspray?
Any cutting compound. G3 etc.
BHadley
Body shop supply places sell something called a "toffee wheel".
Attach to a drill and the old glue should spin off
moggie
I used solvent that is used to clean upvc window frames,sold in b&q ,turns it to soft gel in t mins then wipes off
moggie
