oil change
jon-m42
Post Sat Mar 07, 2015 7:21 pm
Hello Tech Zoners.
I will attempt to carry out a oil change tomorrow.
1: How much oil should I use? I have 8L in total of Castrol 10w- 40.
I had a look at the wiki and it states 4.5L capacity for a 318iS M42 engine.
Just to be sure is this how much I should use?
I understand over filling and under filling can cause issues and damage the engine.
Jon
jmc330i
Post Sat Mar 07, 2015 8:09 pm
4.5L should do it (although I've seen the Wiki say 5L and 4.5L on the same page). I normally add 4L, let it settle and check the dipstick. Then add small amounts of oil, checking the dipstick as I go until its at the right level.
James
'91 325i Sport
'93 318i touring 16v
jon-m42
Post Sat Mar 07, 2015 8:46 pm
Thank you Jmc330i.
I shall follow through the same. Should I fill to the top of the dip stick mark? or should I keep it 3/4 full on the dip stick level ?
Thanks again.
Silverfang
Post Sat Mar 07, 2015 8:53 pm
Best to fill it up to the full mark initially, then start the engine and let the oil pressure light go out. It'll fill up the filter which takes about 0.5 of a litre to do so, and will drop the level.
Once that's done, just top backup with oil till full, though running at 3/4 doesn't do any harm, though it might run a little hotter in the summer as there's a little less oil to soak heat up.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
jon-m42
Post Sat Mar 07, 2015 9:25 pm
Thank you both.
Great help as always. :)
jon-m42
Post Mon Mar 09, 2015 10:03 am
A quick follow on question guys,
BMW are charging £13.42 for a Oil filter which I presume is not so bad.
I checked on ECP and I found a Mann filter for £4.56 ?
Question is which should i go for ? Is there a real difference between the two?
Thanks again.
Jon
scallyally
Post Mon Mar 09, 2015 11:05 am
Difference is about £9.00! And it's a no brainer. The stealers mark up is astronomic.
jon-m42
Post Mon Mar 09, 2015 6:27 pm
Thanks all paid £13.42 to the stealers.
:mad:
