316 stuck in reverse despite the gearstick in neutral
mercdriver
Pretty much as described. Pulled gear lever out of reverse and the car is still in reverse... Gear lever looks like it's in neutral but it's not selecting any gears or going back into reverse
I'll check with the manager
Two possibilities. Either the external linkage has become disrupted/disconnected somehow (get underneath and have a look), or the gearbox has suffered an unusual internal failure.
mercdriver
I reckon it's the rod. I'll look tonight when I actually have time! Thanks for the tech support you two
