rev counter not working
theretroking
Post Tue Feb 24, 2015 11:28 pm
Hi another small issue rev counter is not working any idea to what it could be.
Post Wed Feb 25, 2015 10:28 am
Do the SI lights work as they should and reset properly?
scallyally
Post Wed Feb 25, 2015 2:59 pm
Electrical connector plug clean and tight on diff.?
BenHar
Post Wed Feb 25, 2015 3:17 pm
scallyally wrote:Electrical connector plug clean and tight on diff.?
REV COUNTER.
Ben
scallyally
Post Wed Feb 25, 2015 3:46 pm
Oops, brain fade. :o:
Giggz
Post Wed Feb 25, 2015 3:52 pm
Same sort of issue here actually (1993 318i touring) but then the rev counter sparks into life after a while.
My SI lights do come on as they should, but not reset them...
PS - sorry to hijack thread.
^stolen but not forgotten^
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Feb 25, 2015 4:25 pm
SI lights glowing doesn't necessarily mean they're in working condition. After my battery went flat I lost tacho, SI lights and econometer. After a long charge the SI lights were back on again, but it took another 300 miles driving for the tacho and econometer to suddenly spring into life :D
theretroking
Post Wed Feb 25, 2015 6:02 pm
Sorted was a 7.5 amp fuse :D , thanks for the input guys.
Grrrmachine
Post Wed Feb 25, 2015 6:15 pm
The fuse didn't pop without a reason.
Post Wed Feb 25, 2015 6:32 pm
Giggz wrote:Same sort of issue here actually (1993 318i touring) but then the rev counter sparks into life after a while.
You'll be well advised to take the SI board out of the instrument cluster and replace the batteries in the near future. The batteries have failed, and will soon be leaking a corrosive liquid over the circuit board that contains 99% of the electronics for the instrument cluster.
Post Wed Feb 25, 2015 6:34 pm
theretroking wrote:Sorted was a 7.5 amp fuse :D , thanks for the input guys.
As Grrr says, a blown fuse is a symptom of a fault, not a fault in itself.
Which fuse blew?
theretroking
Post Wed Feb 25, 2015 8:18 pm
Which fuse blew?
The same one which is for the interior lights, there was a short which is now sorted, phew.
mcspike
Post Wed Feb 25, 2015 9:40 pm
Where did you find the fault?
Ryan
Giggz
Post Thu Feb 26, 2015 10:46 am
Thanks Brian, will get on it this weekend.
