rev counter not working
- theretroking
Hi another small issue rev counter is not working any idea to what it could be.
- Brianmoooore
Do the SI lights work as they should and reset properly?
- scallyally
Electrical connector plug clean and tight on diff.?
- scallyally
Oops, brain fade.
Same sort of issue here actually (1993 318i touring) but then the rev counter sparks into life after a while.
My SI lights do come on as they should, but not reset them...
PS - sorry to hijack thread.
^stolen but not forgotten^
Grrrmachine
- E30 Zone Wiki / Team Member
SI lights glowing doesn't necessarily mean they're in working condition. After my battery went flat I lost tacho, SI lights and econometer. After a long charge the SI lights were back on again, but it took another 300 miles driving for the tacho and econometer to suddenly spring into life
- theretroking
Sorted was a 7.5 amp fuse
, thanks for the input guys.
Grrrmachine
The fuse didn't pop without a reason.
- Brianmoooore
Giggz wrote:Same sort of issue here actually (1993 318i touring) but then the rev counter sparks into life after a while.
You'll be well advised to take the SI board out of the instrument cluster and replace the batteries in the near future. The batteries have failed, and will soon be leaking a corrosive liquid over the circuit board that contains 99% of the electronics for the instrument cluster.
- Brianmoooore
As Grrr says, a blown fuse is a symptom of a fault, not a fault in itself.theretroking wrote:Sorted was a 7.5 amp fuse, thanks for the input guys.
Which fuse blew?
- theretroking
The same one which is for the interior lights, there was a short which is now sorted, phew.Brianmoooore wrote:As Grrr says, a blown fuse is a symptom of a fault, not a fault in itself.theretroking wrote:Sorted was a 7.5 amp fuse, thanks for the input guys.
Which fuse blew?
Thanks Brian, will get on it this weekend.Brianmoooore wrote:Giggz wrote:Same sort of issue here actually (1993 318i touring) but then the rev counter sparks into life after a while.
