Hello!
Can any kind person tell me whether a regular E30 fuel tank will fit my 1986 325IX LHD?
I know they are totally different from the windscreen onwards but I am hoping they at least share the same fuel tank?
Mine has a nasty hole and BMW want £690 for an OEM replacement...
Many thanks
Nick
BMW 325ix Fuel tank
Grrrmachine
- E30 Zone Wiki / Team Member
Use Realoem to confirm that the part number matches a similar-age 325i. If it does, then any tank (of the same capacity) should be fine.
- Brianmoooore
Same part. Any 63l tank will fit, or the smaller one can be used with modifications to the electrics and fuel lines.
- Brianmoooore
IIRC., some very early shells wouldn't take the larger tank, but yours almost certainly will.
The fuel return pipe will need moving to a stub pipe on the rear side of the larger tank, it will need a second fuel level sender for the LH side of the tank, and wiring to suit, and the fuel gauge in the instrument cluster will need changing.
