I may be going mad, and this is probably very simple, but:
E36 m52 engine into my 1989 325i.
I have the 4 pin temp sensor connector that drives the dme.
Iv added an e30 single pin coolant temp sensor beside it.
Which wire do I connect to the e30 sensor? Do I simply take the violet wire from the 4pin e36 sensor and connect to the new e30 sensor?
Matt
Coolant temp switch wiring
As simple as that. Cut the purple/brown away from the M52 plug, and connect it to an E30 sensor plug.
mattmk1
Thank you very much! Always worth double checking...
