diff hybrid?
- Brianmoooore
Yes, but setting the correct mesh for the gears is a bit of a specialist job.bosers wrote:Thanks guys. So if I can find a crownwheel and pinion of the right ratio from one of the above then I should be able to swap them into my 3.91 lsd, is that right?
HairyScreech
How come E39 can't be used? I thought all 188 case internal were interchangeable?age wrote:no e39 cant be used, however you can use, e36, e34, e28 and z3 diffs to make a usable diff
As in the case outer changes but the inner parts are nearly standard.
- Contact:
The front end of the pinion is differentHairyScreech wrote:How come E39 can't be used? I thought all 188 case internal were interchangeable?age wrote:no e39 cant be used, however you can use, e36, e34, e28 and z3 diffs to make a usable diff
gareth
And a stock of shims - BMW only and extortionate! Not their most helpful bit of design...heathy325 wrote:Diff mesh can be done at home as I've done it before all you need is engineers ink and patience!!
