diff hybrid?
bosers
Hi, does anyone know if the internals of a med case e39 diff are interchangeable with a med case e30 diff? I'm wondering if I could change the ratio of my 3.91 lsd using taller gears from an e39? Thanks.
age
- Formerly twist316
no e39 cant be used, however you can use, e36, e34, e28 and z3 diffs to make a usable diff
M40 rightness if you can get to 6000rpm noone can hear your tappets
heathy325
I'm currently using a e34 3:23 internals
bosers
Thanks guys. So if I can find a crownwheel and pinion of the right ratio from one of the above then I should be able to swap them into my 3.91 lsd, is that right?
Yes, but setting the correct mesh for the gears is a bit of a specialist job.bosers wrote:Thanks guys. So if I can find a crownwheel and pinion of the right ratio from one of the above then I should be able to swap them into my 3.91 lsd, is that right?
HairyScreech
How come E39 can't be used? I thought all 188 case internal were interchangeable?age wrote:no e39 cant be used, however you can use, e36, e34, e28 and z3 diffs to make a usable diff
As in the case outer changes but the inner parts are nearly standard.
heathy325
Diff mesh can be done at home as I've done it before all you need is engineers ink and patience!!
The front end of the pinion is differentHairyScreech wrote:How come E39 can't be used? I thought all 188 case internal were interchangeable?age wrote:no e39 cant be used, however you can use, e36, e34, e28 and z3 diffs to make a usable diff
gareth
And a stock of shims - BMW only and extortionate! Not their most helpful bit of design...heathy325 wrote:Diff mesh can be done at home as I've done it before all you need is engineers ink and patience!!
