where to get new parts
sh123
hi,
I'm trying to source some new driveshafts, looking for 325 shafts that fit medium case diff.
ive gone down the second hand route once and they were no good so decided to just go for new ones. but I cant seem to find any!
anybody know of anywhere that have some?
cheers
sion
cheers
sion
Mitchen
pony
- I have been misbehaving and am sorry !
BMW Dealer
jmc330i
New driveshafts will be dealer only I expect and as you've seen in your other thread, they will be somewhere around the £1k mark.
How was secondhand no good? There should be plenty of decent used ones available. Drive shafts are all the same iirc, the only difference being ABS and non-ABS.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Unusual to find a duff used driveshaft. Ideally you should fit an ex. LH side one to the RH side, and vice versa.
HairyScreech
I think GSF are doing them still at about £300 per shaft.
Kos
Would you buy them from a dealer at £900 a peicepony wrote:BMW Dealer
Kos wrote:Would you buy them from a dealer at £900 a peicepony wrote:BMW Dealer
Unlikely, though he did buy a GENUINE BMW M20 325 325i SPORT oil filter. Oh hang on.............
Is there any particular reason for this? I would have thought that doing this would stress them, as the torque twist is in the opposite direction to what they've been used to.Brianmoooore wrote:Unusual to find a duff used driveshaft. Ideally you should fit an ex. LH side one to the RH side, and vice versa.
pony
I got SH rear beam from Pacerpete
scallyally
Cos your using the unworn side of the coupling, makes sense,Speedtouch wrote:Is there any particular reason for this? I would have thought that doing this would stress them, as the torque twist is in the opposite direction to what they've been used to.Brianmoooore wrote:Unusual to find a duff used driveshaft. Ideally you should fit an ex. LH side one to the RH side, and vice versa.
Kos
Motorsportpony wrote:Kos wrote:Would you buy them from a dealer at £900 a peicepony wrote:BMW Dealer
Yes, in that sense it does.scallyally wrote:Cos your using the unworn side of the coupling, makes sense,Speedtouch wrote:Is there any particular reason for this? I would have thought that doing this would stress them, as the torque twist is in the opposite direction to what they've been used to.Brianmoooore wrote:Unusual to find a duff used driveshaft. Ideally you should fit an ex. LH side one to the RH side, and vice versa.
HairyScreech
I have learnt recently the suggestion that the CV joints on the outer end of the shafts cannot be changed is bollocks.
The cases can be spilt and then the joints changed and re-staked afterwards. Might be worth looking for some low mileage shafts with compatable CVs and having a bash at putting the low mileage joints on the E30 length shafts.
Auto 316 compact or 1.9z3 CVs might be a good shout for unstressed low mileage joints.
HairyScreech
Add to that the joint are identical in each direction and it means the more worn drive face becomes the over run face.Speedtouch wrote:Yes, in that sense it does.scallyally wrote:Cos your using the unworn side of the coupling, makes sense,Speedtouch wrote: Is there any particular reason for this? I would have thought that doing this would stress them, as the torque twist is in the opposite direction to what they've been used to.
The joints on the E30 don't have to move through much of an angle so don't wear too badly unless lacking lubrication/contaminated or over loaded.
