E46 rear top mounts
Cloggy Saint
jmc330i
Any E46 convertible rear top mount. They are all the same from 318i to M3.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Mitchen
The Meyle HD ones are perfect for the job and only like 12 quid for the pair. They're plentiful on ebay.
http://www.ebay.co.uk/itm/BMW-3-E36-E46 ... 0909560301
Grrrmachine
- E30 Zone Wiki / Team Member
Type Bushes into the Wiki and you'll get the part number.
Cloggy Saint
They look identical to E30 ones, but the difference is supposed to be in the steel bush that the damper rod goes through.
The E30 version uses a simple piece of parallel walled tube, but the equivalent piece on the E46 ones is barrel shaped, so is physically retained in the rubber to a degree, as well as having a larger bonding area for the glue.
bigbird76
I always thought they were identical but thanks for that Brian will take note, Good advice cheersBrianmoooore wrote:They look identical to E30 ones, but the difference is supposed to be in the steel bush that the damper rod goes through.
