E46 rear top mounts
Cloggy Saint
Post Wed Dec 17, 2014 12:43 pm
These are the upgrade for the E30, yes? Any particular year e46? And if anyone has a part number to hand that would be great!
jmc330i
Post Wed Dec 17, 2014 12:54 pm
Any E46 convertible rear top mount. They are all the same from 318i to M3.
James
'91 325i Sport
'93 318i touring 16v
Mitchen
Post Wed Dec 17, 2014 12:55 pm
The Meyle HD ones are perfect for the job and only like 12 quid for the pair. They're plentiful on ebay.
http://www.ebay.co.uk/itm/BMW-3-E36-E46 ... 0909560301
1990 320i Coupe SE
viewtopic.php?t=253048
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Dec 17, 2014 2:19 pm
Type Bushes into the Wiki and you'll get the part number.
Cloggy Saint
Post Wed Dec 17, 2014 7:51 pm
Good stuff, thanks.
Post Wed Dec 17, 2014 8:53 pm
They look identical to E30 ones, but the difference is supposed to be in the steel bush that the damper rod goes through.
The E30 version uses a simple piece of parallel walled tube, but the equivalent piece on the E46 ones is barrel shaped, so is physically retained in the rubber to a degree, as well as having a larger bonding area for the glue.
bigbird76
Post Thu Dec 18, 2014 11:10 pm
Brianmoooore wrote:They look identical to E30 ones, but the difference is supposed to be in the steel bush that the damper rod goes through.
I always thought they were identical but thanks for that Brian will take note, Good advice cheers
