Pollen filter??
Sambe30
Post Sat Dec 13, 2014 9:41 am
Hi guys, under the pull out nob for the lights on the right hand side there is a square space with a cut out circle which appears to have a filter or sponge looking thing in there? Anybody know what that is?[/img]
Post Sat Dec 13, 2014 9:45 am
No pollen filters on E30's
Not sure what you are describing can you post a pic
Post Sat Dec 13, 2014 10:13 am
capri_rob wrote:No pollen filters on E30's
ETK does list one.
What size is this square cut out and circle? If it's only a couple of inches across, it's the mounting position for the OBC gong.
Sambe30
Post Sat Dec 13, 2014 10:17 am
I'm on my mobile phone and don't know how, http://pages.ebay.com/link/?nav=item.vi ... 1514697384 see 11th pic on here it is on the right, under the light pull out this one has a cap over the top mine dosent, I don't think all e30s have it
Sambe30
Post Sat Dec 13, 2014 10:18 am
Pictures just above accelerator pedal in the pic
Post Sat Dec 13, 2014 10:33 am
Are you referring to the headlight leveller?
Sambe30
Post Sat Dec 13, 2014 10:38 am
Is that what it is then? Mine is just a hole with something that looks like a sponge inside
Cloggy Saint
Post Sat Dec 13, 2014 10:52 am
Don't worry, even if you did have the levelling knob it probably wouldn't work.
Post Sat Dec 13, 2014 11:12 am
Pollen filter for some LHD only cars.
Mitchen
Post Sat Dec 13, 2014 11:21 am
Cloggy Saint wrote:Don't worry, even if you did have the levelling knob it probably wouldn't work.
So true :chuckle:
1990 320i Coupe SE
viewtopic.php?t=253048
Demlotcrew
Post Sun Dec 14, 2014 12:13 pm
Polen was available for E30's and also for RHD models, the filter would break up in to four parts to get it past the pedals.
Post Sun Dec 14, 2014 2:20 pm
Where does it fit on rhd cars Andrew?
Demlotcrew
Post Sun Dec 14, 2014 4:12 pm
The exact same place as on the LHD cars (where the AC evaporator would be).
