Pollen filter??
Sambe30
Hi guys, under the pull out nob for the lights on the right hand side there is a square space with a cut out circle which appears to have a filter or sponge looking thing in there? Anybody know what that is?[/img]
No pollen filters on E30's
Not sure what you are describing can you post a pic
ETK does list one.capri_rob wrote:No pollen filters on E30's
What size is this square cut out and circle? If it's only a couple of inches across, it's the mounting position for the OBC gong.
Sambe30
I'm on my mobile phone and don't know how, http://pages.ebay.com/link/?nav=item.vi ... 1514697384 see 11th pic on here it is on the right, under the light pull out this one has a cap over the top mine dosent, I don't think all e30s have it
Sambe30
Pictures just above accelerator pedal in the pic
Are you referring to the headlight leveller?
Sambe30
Is that what it is then? Mine is just a hole with something that looks like a sponge inside
Cloggy Saint
Pollen filter for some LHD only cars.
Mitchen
So trueCloggy Saint wrote:Don't worry, even if you did have the levelling knob it probably wouldn't work.
Demlotcrew
Polen was available for E30's and also for RHD models, the filter would break up in to four parts to get it past the pedals.
Where does it fit on rhd cars Andrew?
Demlotcrew
The exact same place as on the LHD cars (where the AC evaporator would be).
