Ticking noise, EVAP?
CarlNewman
Post Thu Sep 11, 2014 11:22 pm
Done my m52 swap, had it all running but after it was sat running on idle for a while it developed a tapping noise. I've been told it can be down to the EVAP purge system? On the e36 it plugs into a canister. What do people do about this on a e30
rich318i
Post Fri Sep 12, 2014 12:33 am
blank it off
Post Fri Sep 12, 2014 9:02 pm
Pipe into the inlet plenum has to be blanked off, but I can't see what this has to do with any tapping noise.
I'd be checking that you have the heater pipes the right way around.
