I understand its the brown/ violet wire i need to be using but does it still need to run to the original sensor as well as the e30 one.
Brown Temp Sensor Wiring
jmc330i
No, the M52 sensor is kept to send the temp to the ECU only.
You add the E30 brown temp sensor for the temp gauge - you will need to run the brown/violet wire from the C101 Pin4 to the E30 sensor.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
HairyScreech
Brown sensor for the gauge cluster, blue for the motronic, black for the M5x motronic.jmc330i wrote:No, the M52 sensor is kept to send the temp to the ECU only.
