Brown Temp Sensor Wiring
ashje
Post Tue Sep 09, 2014 7:32 pm
I understand its the brown/ violet wire i need to be using but does it still need to run to the original sensor as well as the e30 one.
jmc330i
Post Tue Sep 09, 2014 8:17 pm
No, the M52 sensor is kept to send the temp to the ECU only.
You add the E30 brown temp sensor for the temp gauge - you will need to run the brown/violet wire from the C101 Pin4 to the E30 sensor.
James
'91 325i Sport
'93 318i touring 16v
ashje
Post Tue Sep 09, 2014 10:40 pm
Excellent, thanks
HairyScreech
Post Sat Sep 13, 2014 6:22 pm
jmc330i wrote:No, the M52 sensor is kept to send the temp to the ECU only.
Brown sensor for the gauge cluster, blue for the motronic, black for the M5x motronic. :wink:
