dohh!
fredbloke
Post Sat Aug 30, 2014 12:40 pm
Whe removing my gearbox from the m52 the two mounting points either side one broke in half and the other i snapped the bolt in under very low pressure. I covered them in wd40 prior to removal. Any ideas
Post Sat Aug 30, 2014 1:17 pm
I presume you mean the mounting points on the gearbox itself? You may be able to get them aluminium welded...
Pics would help with the diagnosis. :wink:
fredbloke
Post Sat Aug 30, 2014 3:10 pm
Nope the ones on the block. That the box mounts too. Will get some pics up
