dohh!
fredbloke
Whe removing my gearbox from the m52 the two mounting points either side one broke in half and the other i snapped the bolt in under very low pressure. I covered them in wd40 prior to removal. Any ideas
I presume you mean the mounting points on the gearbox itself? You may be able to get them aluminium welded...
Pics would help with the diagnosis.
fredbloke
Nope the ones on the block. That the box mounts too. Will get some pics up
