Keep breaking inner cv joints
l33-lsh
Fri Aug 22, 2014 9:34 pm
Hello all, I can't find anywhere that sells inner cv joint kits. Keep spinning it off the splines as busting the joint up. That seems to be the weakest point so I want to re build my shafts and then weld the coupler on the shaft :)
bmw9818
Fri Aug 22, 2014 9:55 pm
what you running?
l33-lsh
Fri Aug 22, 2014 9:57 pm
2.5 welded diff
l33-lsh
Sat Aug 23, 2014 10:45 am
Bump
ross_jsy
Sat Aug 23, 2014 11:00 am
Stop being cheap and buy an LSD?
Andyboy
Alpina Colada
Sun Aug 24, 2014 8:24 am
l33-lsh wrote:2.5 welded diff
And all is revealed.
Sun Aug 24, 2014 8:31 am
Just weld them up solid innit
Andyboy
Alpina Colada
Sun Aug 24, 2014 9:00 am
I welded the crankshaft to the block and I keep burning out starters Dan. Any ideas?
sweep
Sun Aug 24, 2014 9:06 am
ring gear?^^^^
Sun Aug 24, 2014 2:53 pm
Andyboy wrote:I welded the crankshaft to the block and I keep burning out starters Dan. Any ideas?
Tow start it, that will get the fooker turning, and if it doesnt at least you can burn the rear tyres out and take a selfie pic
l33-lsh
Thu Aug 28, 2014 9:18 am
Alright alright alright lol
Anyone got a lsd for sale then that's not a million pound like they are on eBay.
Thu Aug 28, 2014 11:48 am
Rotary? :)
Motorhole
Thu Aug 28, 2014 12:28 pm
£250-£350 is the going rate for a used LSD and most of these will probably require a rebuild anyway...
Save up :D
Phill172
Thu Aug 28, 2014 12:47 pm
I do the same, seems to be better the newer the driveshaft (waits for comments)
How low is your car? They really don't like crazy camber at the back, when are they breaking? With a welded diff you want to avoid 90 point turns as they really do you no favous
Phill172
Thu Aug 28, 2014 12:49 pm
And as for an LSD, depending what the application is, id rather not spend the money on a diff that will do the job properly (for me) as frankly I'll spend lots of money on a rebuilt/getting it to lock up as I require for it then to basically drive the same as a welded diff!
l33-lsh
Thu Aug 28, 2014 9:48 pm
They seem to be breaking while doing a burnout and the rear judders, think I need a taller tyre which should help to break traction easier and harder shocks and springs.
ross_jsy
Thu Aug 28, 2014 9:58 pm
Sounds like axle tramp. It kills drivetrains
Phill172
Thu Aug 28, 2014 10:24 pm
What's the full spec of your car?
Burnouts for a reason or being a hero?
l33-lsh
Thu Aug 28, 2014 11:13 pm
Just a hero :)
Bought the car with lowered springs and uprated dampers not sure on suspension spec or make. 16 inch wheels with low profile tyres ( I think this is possibly 1 of the reasons.)
Phill172
Fri Aug 29, 2014 9:29 am
I found that tyres dont really change it, with 245s ill snap cvs with 195s ill still snap them.
Camber seems to be the biggest factor as as above just try and get new or ones with not many miles on...
If your burnout king than linelock will release some of the stress as you wont be on the rear brakes....
Fri Aug 29, 2014 10:18 am
Fitting springs that bring the suspension geometry back into the area where it actually works, losing the insurance invalidating diff. and stopping driving like a complete dick seems to be the obvious solution to your problems.
driftwood
Fri Aug 29, 2014 10:37 am
Why would it be insurance invalidating? Here we go again....
Not a purist.
Fri Aug 29, 2014 10:42 am
Right, I'll ask a direct question: Has the OP, or yourself, if you have one, declared this modification to your insurer?
Phill172
Fri Aug 29, 2014 10:51 am
Mine is :D
Fri Aug 29, 2014 10:53 am
It's a f0000king lifestyle, man :)
PS I have lots of good driveshafts for sale . Discount for bulk orders :D
Fri Aug 29, 2014 1:29 pm
Will you be bringing some to santa pod pete? The lifestylers will be on overload this year
l33-lsh
Fri Aug 29, 2014 9:02 pm
I'm hopefully going to be in the drift arena lads at Santa pod. I will have some some driveshafts :)
Phill172
Fri Aug 29, 2014 10:38 pm
l33-lsh wrote:I'm hopefully going to be in the drift arena lads at Santa pod. I will have some some driveshafts :)
On the UKs only off-road drift area
