supercharging idle control/fuel managment
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Aug 18, 2014 8:46 pm
Im currently collecting bits up ready to supercharge in the winter im fitting a eaton 90 to a m20b28 now the question I have is - has anyone any idea how I get round idle control? Obviously the charger will be spinning/boosting at idle running of the crank pully now would this effect the idle as im envisioning it idleing high also what management would anyone recommend?
gromgsxr
Mon Aug 18, 2014 9:24 pm
any stand alone management should be adaptable enough for you to get a decent idle with. and depends how handy you are with wiring ect but megasquirt is an option.
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Aug 18, 2014 10:49 pm
Im very good with wiring, ill take a look at ms, ive also figured out the placment for the idle stabilizer. Looks like im going to have to run a intercooler on the m90 too
ross_jsy
Mon Aug 18, 2014 10:54 pm
Why not turbo? Size it properly and it won't be laggy and does away with the huge pumping losses a supercharger suffers from
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Aug 18, 2014 11:03 pm
Im not a fan of turbos dude ive always found superchargers suit my driving style so much better.
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Aug 18, 2014 11:04 pm
If I run megasquirt I can build this supercharger set up with tuning for under 1100... itd be double at least to turbo.
