Mat Locks
Mitchen
Guys this will no doubt be a short 1 reply thread.. but just collected these mat locks today
http://www.realoem.com/bmw/showparts.do ... g=51&fg=55
How do I fit? Does the carpet have to come out?
beemerbird
Screw them in through the carpet to latch your mats on.
beemerbird
You'll have to hope the fixing points aren't damaged. Two replies at least
Mitchen
lol thanks beemerbird.. The screw fixings do screw straight into the carpet and attach, so hopefully nothings damaged beneath the carpet, but the holes in the mats are too big for them to be used alone. So where do the 2 discs come into it? Because if put the discs under or over the mats, the screw isnt long enough to reach the carpet.
Probably real simple but I'm overly confused here
beemerbird
It looks to me that those two discs clip from above and below into the mat, making the mat hole size work?
Mitchen
No doesnt fit
this makes the distance between the first disc, through the mat, and then through the second disc, longer than the thread on the screw.
Even the parts order guy at the dealers was baffled, he didnt know either.
They are genuine E30 mats for the record.
kam-325i
OK.....It goes like this....
Screw the Bottom item in the picture into the carpet.
The Middle item fits on the underside of the mat through the pre cut hole....
The top item then, from the top of the mat, snaps into the one fitted under the mat, so that the slot part should then be flush with the underside of the mat.
Mitchen
BenHar
Those mats need this part: http://www.realoem.com/bmw/showparts.do ... g=51&fg=95
Cut the old bit of plastic out of the mat and make the hole the right size for your new clips.
Ben
Ben
kam-325i
Those are the wrong ones for that mat.
this is the type you need for that mat
http://www.ebay.co.uk/itm/SKODA-FLOOR-M ... 27e5314c40
Mitchen
Thanks Ben the only way it's going to happen isnt it.. thanks guys appreciate all your help
Mitchen
Oh these will fit the E30 mats? Nice one Kam, much appreciatedkam-325i wrote:Those are the wrong ones for that mat.
kam-325i
I don't know whether the ones I have shown will fit you mats, but it gives you a good idea on what they should look like,
Mitchen
Ok nice one. Thanks a lot.
polsta
This part listed is that you need , just get part 3 , and they just screw in to the carpet and the top turn locks in to the metal bit in your carpet , they still available from bmwBenHar wrote:Those mats need this part: http://www.realoem.com/bmw/showparts.do ... g=51&fg=95
Ben
Mitchen
Thanks Polsta
