Fuse 12 blown - damage the components?
bmwlover
Post Fri Jul 04, 2014 12:07 pm
Hi
I saw there was a wire cut up underneath the dashboard (the big cover under the steering wheel) I was wondering why there were cut in it
it went to ground and an end with cable Joints (between there was the cut) so I tried to put them together, and then came a spark ... I found out that my radio did not turn on.
I checked the fuse box. Fuse 12 was blown. I Put a new fuse
in and now it works again
Question:
Can it damage any electrical components when there is a short-Circuit???
bmwlover
Post Fri Jul 04, 2014 12:27 pm
diable wrote:Yes if the fuse is rated too high the reason for fuses are for them to blow before any damage occurs like in this case.
okay, the fuse is the original rating = 7,5
as long as it is the original rating, then there is nothing that could be damaged?
do not know much about the electrical
Post Fri Jul 04, 2014 12:39 pm
Yes, it should be fine, but ensure that any stray wire ends are insulated with electrical tape (or cut off).
bmwlover
Post Fri Jul 04, 2014 12:50 pm
Okay thanks alot! was afraid that something could have been damaged
I will remove the wire which has been cut
