I know that for adjusting the valve, the camshaft lobe must be pointing directly downwards for that valve you are adjusting. But I'm finding it pretty hard to tell if the lobe is fully down or not, or to an angle.
How do I go about making sure I have the camshaft in the correct position when adjusting each valve?
The engine is now even more noisier than before!
