Thought it would be a piece of cake, so started work on it and when i removed the bulkhead panel i was greated with this:
I was looking out for some white straps, that i had seen when looking at various online threads and a sort of cover under that
Well i proceeded to remove the outer panels to expose the blower motor and it looked like this underneath:
Firstly a lot of mess and debris that got clogged up in the fan blades itself.
But it also looked like non of the heater blower motors i had seen when looking at online removals guides. i hadn't seen many if any this these two big "air scoops" underneath each fan.
I wanted to know if my blower motor is correct for an '89 325i? As someone has clearly been here before me. And as what i found when i removed the panel matched nothing i had seen online.
And after all that i couldn't get a metal strap off to remove the motor
