rear spring pads
FMH
How thick are the standard rear spring pads (new)?
FMH
Upper and lower
j4gz
They come in three sizes I think there is a 3mm 5mm and 10mm from what I can remember and model spefic
FMH
for the rear, apparently upper is one size, not able to choose, rear is standard, 5mm, 7.5mm, 10mm, so need to know what the standard is
Sanchez
5, 7.5 and 10mm on realoem.
3mm front pads from e90/92.
FMH
i've got e36 m3 front set up so got 3mm for them.Sanchez wrote:5, 7.5 and 10mm on realoem.
rears lower option is 5, 7.5, 10mm, uppers don't state thickness
Sanchez
Upper and lower are both the same I though.
Mitchen
Upper is one size, lower is variable, I've got a set of both at home ready to be fitted when I get time. 7.5mm is the standard for lower.
harry_p
There isn't a standard size, it depends on the market the car is for and the options fitted.
cheers,
harry
harry
