rear spring pads
FMH
Post Thu May 22, 2014 9:46 pm
How thick are the standard rear spring pads (new)?
FMH
Post Thu May 22, 2014 9:47 pm
Upper and lower
j4gz
Post Thu May 22, 2014 11:54 pm
They come in three sizes I think there is a 3mm 5mm and 10mm from what I can remember and model spefic
FMH
Post Fri May 23, 2014 12:18 am
for the rear, apparently upper is one size, not able to choose, rear is standard, 5mm, 7.5mm, 10mm, so need to know what the standard is
Sanchez
Post Fri May 23, 2014 12:19 am
5, 7.5 and 10mm on realoem.
3mm front pads from e90/92.
FMH
Post Fri May 23, 2014 12:41 am
Sanchez wrote:5, 7.5 and 10mm on realoem.
i've got e36 m3 front set up so got 3mm for them.
rears lower option is 5, 7.5, 10mm, uppers don't state thickness
Sanchez
Post Fri May 23, 2014 10:06 am
Upper and lower are both the same I though.
Mitchen
Post Fri May 23, 2014 8:17 pm
Upper is one size, lower is variable, I've got a set of both at home ready to be fitted when I get time. 7.5mm is the standard for lower.
1990 320i Coupe SE
viewtopic.php?t=253048
harry_p
Post Fri May 23, 2014 9:06 pm
There isn't a standard size, it depends on the market the car is for and the options fitted.
cheers,
harry
