M42 Engine Map (DTA ECU)
Minimayhem81
Post Thu May 08, 2014 4:24 pm
Bit of a long shot but has anyone go a basic start map or values I can use to get my M42 running on my old DTA ecu?
Thanks Neil
Post Thu May 08, 2014 4:29 pm
You'll need to get a map with the correct firmware version (there were three) or it will either idle badly or not run at all.
Do you have the original BMW chip number?
Minimayhem81
Post Thu May 08, 2014 5:57 pm
Yeah I have the current ECU I can open this up if needed, but I can't confirm this is the original ECU for this engine would it make any difference? ( idles like a turd at the moment so could be?)
I don't mind if it runs badly as I will tune this out eventually as I'm converting this to throttle bodies... Just wanted a starting point as I can't even make it run as a standard engine yet.
Post Thu May 08, 2014 6:21 pm
I can supply a 318is bin (binary) file via e-mail for a small fee.
Minimayhem81
Post Thu May 08, 2014 6:40 pm
How would I use this on my DtA? The file type it opens are .MAP files...
Post Thu May 08, 2014 6:46 pm
Most software editors will allow you to convert between the various file formats - do you use TunerPro or similar?
Minimayhem81
Post Thu May 08, 2014 6:56 pm
I currently use the DTAwin software.
Post Thu May 08, 2014 7:01 pm
Does it not allow you to convert .bin files into .map ones?
Minimayhem81
Post Fri May 09, 2014 10:34 pm
Not that I can see...
Post Fri May 09, 2014 10:38 pm
Isn't there a dedicated forum that you can visit for .map files?
Minimayhem81
Post Fri May 09, 2014 11:11 pm
Maybe I'll have alook :)
