Clonked my sump ! .. Advice please
Walter
Post Sun Apr 13, 2014 2:36 pm
I have a 1990 H reg E30 318i touring... Been my workhorse for 2 years and has been good to me.
Clonked the sump this morning down an unmade road... Only a small clonk.... Had worse in my time !
Oil light came on several miles down the road & I realised what had happened.... No oil on the dipstick and oil oozing out the bottom of the engine !... Haven't had a chance yet to have a good look underneath to see what I exactly did.
My question is... if I've cracked the sump, can it be replaced without taking the engine out ???
It's only done 80,000 and I don't want to lose the car, but if it's an engine out job it may have to go.
Thanks in advance for any replies.... Steve.
Cloggy Saint
Post Sun Apr 13, 2014 2:45 pm
The engine doesn't need to come out but you will have to raise it so the sump clears the subframe.
No need to remove the engine
Post Sun Apr 13, 2014 3:21 pm
there are two parts to the sump ,if it only cracked you can get it alloy welded for about £50 ,when you take the lower bowl off you need to check the upper part isn't fractured .
worst case scenario i have this for sale...
http://www.ebay.co.uk/itm/171293401969? ... 1555.l2649
Post Sun Apr 13, 2014 8:42 pm
Chances are you've only cracked the lower sump, and this can be replaced easily without moving anything other than the engine under shield.
Plenty of M40 engined scrappers around. A complete engine can be bought for scrap value, so the sumps aren't particularly valuable. When the sump is off, check that three (?) bolts inside the sump that hold the upper sump to the engine block are tight. It's quite common for these bolts to fall out and lie in the bottom of the sump.
Walter
Post Mon Apr 14, 2014 10:19 am
Appreciate the replies..... Very helpful...... I know now that I can take this job on myself..... Thanks... Steve.
