Wiring Question
Robbo-80
Post Fri Mar 14, 2014 10:36 am
Wiring up my electric fan loom from Danthe, have hooked up to fuse 3 & relay K1 but not too sure where to connect the 3rd wire (black/brown), think it should connect to a green/black wire in my fuse box, but only colour of wire that's green/black is into fuse 19!!
Anybody out there that can point me in the right direction?
jmc330i
Post Fri Mar 14, 2014 11:24 am
I'm not sure on the wire colours, but from memory, power to the temp switch comes from fuse 19.
James
'91 325i Sport
'93 318i touring 16v
Robbo-80
Post Fri Mar 14, 2014 11:36 am
I've got 2 black/green wires into fuse 19.
1 wire comes from inside the car & the other has a connector on the end with a black/white wire.
Any idea what 1 I connect up to?
Post Fri Mar 14, 2014 12:01 pm
I would have emailed you instructions for this mate
jmc330i
Post Fri Mar 14, 2014 12:42 pm
Dans the man to help with one of his looms 8)
But here's how I wired my fan in...
http://www.e30zone.net/e30zonewiki/inde ... n#Fuse_Box
James
'91 325i Sport
Post Fri Mar 14, 2014 6:12 pm
i got a pdf file on how to fit the loom when i got mine from Dan.....even i managed not to fook it up :D
craigieeb
Post Fri Mar 14, 2014 6:47 pm
magpie wrote:i got a pdf file on how to fit the loom when i got mine from Dan.....even i managed not to fook it up :D
You would try and chop your leg off if you were left alone for 5 minutes :D
Post Fri Mar 14, 2014 7:23 pm
8O
craigieeb
Post Sat Mar 15, 2014 2:37 pm
:teehee:
bet your laid up on the settee, getting your lass to do everything, poor mick
:lol:
