Suspension/spring help
Fiddy
Post Mon Feb 24, 2014 4:03 pm
Hi everyone
I have a 325i cabby that I recently purchases brand new. Bilstein B12 kit and rougue engineering top mounts.
I'm very happy with the rear height of the car but wouldn't mind the front to sit slightly lower.
Would anyone recommend anything. I hve seen H&R do some slightly lower but don't want the rear to to drop further.
Many thanks
Fiddy
Post Mon Feb 24, 2014 4:18 pm
Would I be able to leave my current Eibach 30mm on the rear and put the H&R on the front, or would people avoid that.
I would be nice to be able to sell a set of springs though so I haven't got a miss matched set in my garage that I wouldn't really be able to sell
G-Bear
Post Mon Feb 24, 2014 6:46 pm
I'm sure there's a top mount you can take from a different BMW that fits and allows a slightly lower ride height. That way you wouldn't have to worry about different springs up front.
Do a little search on here.
Either that or someone will come along with more information soon enough..
SAP1
Post Mon Feb 24, 2014 7:16 pm
I think to make the car lower at the front you can use an E90 top mount
harry_p
Post Mon Feb 24, 2014 7:30 pm
It's not the top mount, it's the upper spring cup, its deeper so the spring sits up a little higher.
cheers,
harry
SAP1
Post Mon Feb 24, 2014 7:32 pm
That's what I mean^
G-Bear
The top hat? I wasn't sure if they were the same thing.
Fiddy
Post Mon Feb 24, 2014 8:34 pm
Hmmm will have to try and research this. I don't want to be changing the suspension really as the Bilsteins are brilliant so not really sure what to do. If it sat 20mm lower on the front it would be perfect
e30rapidic
Post Mon Feb 24, 2014 8:35 pm
yes, you can use an e90 top hat on an e30. I believe it will drop you an additional 15mm.
Or you could remove the spring perch pads for about 4-5mm.
rich318i
Post Mon Feb 24, 2014 8:51 pm
You sure you dont have to drill new holes for the E90 top mounts ?
Fiddy
Post Tue Feb 25, 2014 8:22 am
Anyone have any more info on this l.
suedenim
Post Tue Feb 25, 2014 8:53 am
Fiddy wrote:Anyone have any more info on this l.
Iirc they have been used on this build, which to my my mind sits just perfectly
http://www.e30zone.net/modules.php?name ... c&t=144893
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
harry_p
Post Tue Feb 25, 2014 11:18 am
Just a thought, the e90 top hats might not work with aftermarket top mounts as they need the depth of the standard mount to sit inside the perch :?
cheers,
harry
Morat
Post Tue Feb 25, 2014 11:35 am
The Rogue Engineering mounts are for the rear.
Fiddy
Post Tue Feb 25, 2014 11:38 am
Sorry yes you are correct with rear mounts :-P my bad haha
G-Bear
Post Tue Feb 25, 2014 12:45 pm
I seem to remember Kedge either knowing about it or puting them on one of his E30's. Might be worth sending a PM his way.
e30rapidic
Post Tue Feb 25, 2014 5:27 pm
search r3vlimited.com. Quite a few e30 owners have done it
